Dimond Lighting D2604-LED 1 Light 28.75 Height LED Table Lamp from
Single Light 28.75" Height LED Table Lamp from the TRUMP HOME Collection Features: Sand Linen fabric square shade Made of metal and acrylic Designed to cast light both upwards and downwards Energy efficient Suitable for dry locations Lamping Technology: Bulb Base - Medium (E26) : The E26 (Edison 26mm) , Medium Edison Screw, is the standard bulb used in 120-Volt applications in North America. E26 is the most common bulb type and is generally interchangeable with E27 bulbs. Compatible Bulb Types: Nearly all bulb types can be found for the E26 Medium Base, options include Incandescent, Fluorescent, LED, Halogen, and Xenon / Krypton. LED - Light Emitting Diode: Highly efficient integrated diodes produce little heat and have an extremely long lifespan. Specifications: Base Style: Pedestal Bulb Base: Medium (E26) Bulb Included: Yes Bulb Type: LED Height: 28.75" LED: Yes Location Rating: Dry Location Lumens: 800 Material: Other Metals Number of Bulbs: 1 Shade Height: 11" Shade Length: 15" Shade Width: 16" Switch Type: Multi Way Voltage: 120v Wattage: 9.5 Watts Per Bulb: 9.5 Width: 15.5" (measured from furthest point left to furthest point right on fixture) About Dimond Lighting: Dimond Lighting innovations, inspired by the poetry of light and acclaimed for elegance with which they are executed, originate from the desire to transcend the boundaries of innovation and style. Such an ambition requires the willingness to constantly surpass one's own expectations. Find the perfect table or floor lamp complement to complete the application of the DIMOND style to your home.
